thought it was the timming at first but got all the timming done n still doing it ne ideas!
morrisman1,
Jul 20, 4:31pm
AFM unplugged or faulty
Jul 20, 4:31pm
What else was done to the engine!
morrisman1,
Jul 20, 4:46pm
If it is smoking black smoke when you hold it at the 1500 rpm limit is is almost certainly a dud AFM. Does it have an oiled pod filter!
lisa.leann,
Jul 20, 4:49pm
i have swap afm with one out off a running car n check the plug at the same time n still doing it
Jul 20, 4:52pm
Blocked exhaust maybe!
lisa.leann,
Jul 21, 10:23am
forgot the say its plus t(turbo) n would say more on the eletrical side . would a knock sensor cause this!
motorboy2011,
Jul 21, 11:33am
what ecu are you using!
treachug,
Jul 21, 11:46am
Faulty coil(s)!
falcon15,
Jul 21, 2:04pm
sounds like a afm to me aswell. have you checked no intercooler pipes have blown off that will give the same symptoms of a stuffed afm. i would also check the afm wiring
