SRS light
zak1998, Aug 24, 7:44am
Can anyone help as the light on the dash came ondue to the wire under the seat got knocked and now the light won't go out
saxman99, Aug 24, 7:46am
Depending on the type of car it may need to be hooked up to an SRS computer for a reset.Some cars also have a reset sequence which can be used.
zak1998, Aug 24, 7:52am
Honda car
incar., Aug 24, 8:14am
Pink Honda car!
zak1998, Aug 24, 8:23am
Reading about a paper clip in the yellow plug will reset it. Now to find it
tmenz, Aug 24, 8:30am
Honda what!
My Honda Legend needed about 8 initialisation attempts on the passenger seat occupancy sensor before the SRS computer and light would reset. This was on a Honda workshop analyser!
kazbanz, Aug 24, 8:40am
I'd still try the disconnect the battery for 10 minutes trick--n o harm in it
-do drive the car for a couple of KM though as sometimes they take a few check cycles to reset
texastwo, Aug 24, 9:06am
Well at least you know its just the underseat wire. As others have said you probably need to be hooked up to a diagnotics to get the codes to reset it. Not like others I know that have been told they needa new Airbag ECU at a cost of around $1000
kcc55a, Aug 24, 9:09am
Isnt there a possibility that re-hooking up the battery could cause the airbag to go off!
kazbanz, Aug 24, 10:48am
How!
neo_psy, Aug 24, 11:52am
If you're not watching the road while you're hooking up the battery and run into someone.
(sorry, I'll do some work now)
zak1998, Aug 24, 11:57am
All fixed guy at the garage did it with the machine $20 all up
kazbanz, Aug 24, 1:56pm
Get back to your tranz shipping
shadowzz, Oct 27, 12:45pm
What garage was that!
