It only when I put my foot down. Drops coolant afterwards. If I drive slowly it's stays in.Do you reckon it's a hose or the radiator!
a.woodrow,
Sep 9, 11:28am
I reckon it's the blown head gasket or cracked head. What kind of vehicle!
therafter1,
Sep 9, 11:31am
I reckon the first step is a pressure test.
ourtwomonkeys,
Sep 9, 11:41am
Jeep Grand Cherokee 1999
Best I go get it checked out properly
therafter1,
Sep 9, 11:45am
Best you do.
There are two fluids that are essential to the longevity of water cooled internal combustion engines, coolant and oil . running them without them is usually ultimately fatal.
unbeatabull,
Sep 9, 12:19pm
And petrol . they don't go very far without it!
ceebee2,
Sep 9, 2:18pm
Does this model have the recovery tank!.if not then it has simply been overfilled. If it has then check the actual water level in the radiator (When cold) and the recovery tank. If this is over filled will also overflow when hot.
