We used Warlocks last time, they were ok but if someone can recommend someone better that would be good.
Preferably someone who will come to your home/work to do it.
Sep 8, 9:03am
gps tracker is the only alarm to install
elect70,
Sep 8, 10:44am
^^^as he says, there arealreadyalarm/imobilisersdisablerscan buy& then break in & steal it ,Still, it should stop the joy ridersbut not a serious theif .
mrfxit,
Sep 8, 10:48am
THAT. has always been the case, alarms slow down the lazy burgers, nothing stops the serious thieves
tracemyster,
Sep 8, 2:40pm
Also wanting it as a deterrent for those who break the side panel window and rummage around looking for anything valuable which has happened numerous times on our street.
johnf_456,
Sep 8, 2:49pm
Just get a cheap alarm to alert you if someone breaks a window or opens the door plus you get keyless entry if your car does not have it already.
Then do the gps tracker and hide it well for better security from professional thieves, a cheapy alarm will stop the average teenage joyriders which just break the barrel and bridge the ignition wires.
whqqsh,
Sep 9, 6:59am
Ive just had a Mongoose installed, Reber Autoelectrical in Mt Roskill did a great job (as always), dont think they do mobile though
motorboy2011,
Sep 9, 7:18am
so leave nothing of value in your car and leave the doors unlocked. Problem solved.
motorboy2011,
Sep 9, 7:20am
and get a gps tracker, then you can set it up to txt you when the lil shits open your door, and you can catch them in the act. Far better than having an alarm siren that scares them off.
splinter67,
Sep 9, 7:23am
I agree and if you want a deterrent get a flashing led mounted on your dashboard
clark20,
Sep 9, 8:34am
Yep, Warwick has always run a good operation
