How much to fix the rust in this.
alleycatz, Oct 3, 6:25pm
couple hundy should do it - thats litres . of BOG !
un_known, Oct 3, 6:29pm
maaate shes a minter.
bmc460, Oct 3, 6:38pm
Looks like bluff in background,plenty of salt there.
gammelvind, Oct 3, 6:40pm
A big can of newtech and a coat of fast dry, the wof inspector would never suspect a thing.
gunhand, Oct 3, 6:42pm
Newtech, na to hard to sand, unless with a grinder lol. Maybe just paint it all rust brown!
tigra, Oct 3, 6:45pm
Youwill note auctions says "must pick up"probably not driveable
gunhand, Oct 3, 6:48pm
Also says goes good, full chassis so shouldnt full off.although.
hrt, Oct 3, 6:57pm
It's all surface rust, she'll be right
00quattro00, Oct 3, 7:26pm
I went and looked at an old e21 bmw that wasnt much better, guy reckoned he could fix it in an afternoon
buyme3, Oct 3, 7:27pm
is that a great wall! hard to see from those angles. 2008!
dasfi, Oct 3, 7:44pm
Send it to the wreckers
johnf_456, Oct 3, 8:01pm
More like scrap metal
mrfxit, Oct 3, 9:06pm
It's like this.
Modern vehicle panels tend to rust over a much larger area then just what you see.
Old vehicle panels like the Toyota tend to have rust ONLY where you see it, the rest of the panels will be ok most times.
It's a bit like 20 years ago, I could use the panel steel off an old whiteway 400 washing machine to do rust repairs.
It was a total waste of time trying to use the panels from a Gentle Annie
snoopy221, Oct 3, 10:58pm
Aye fully epoxy coated weld the right side fold the right way-
And ya wanna use rusted untreated NEW steel!
mrfxit, Oct 4, 8:46am
It was more of a statement about how things have changed.
The old Whiteway steel was a pretty std mild steel of comparable thickness to the steel used on a lot of 70's / 80's cars.
The Gentle Annie steel was a thinner & higher tensile steel that behaved very badly when using an oxy/acet welder
With the old steel, what showed as rust on the outside surface, was mostly confined to the same area on the inside.
5 cent bubble outside / 50 cent size inside
With the newer steel, what rust showed on the outside was often a lot smaller then what was rusting away on the inside.
5 cent bubble outside / 2 x $5 note+ size inside
thejazzpianoma, Oct 4, 9:33am
What metal!
3tomany, Oct 4, 9:41am
not enough steel left to scrap
johnf_456, Oct 4, 11:44am
Whats left after a strip down. Yeah not much steel but some.
trogedon, Oct 4, 2:00pm
It would be fun to take it over a jump or two and see what was left.
