2001 ford courier gearbox
kecal, Oct 14, 6:01pm
hello
my ford courier has just dropped 5th gear is there a rebuild kit for this!because new or secondhand box is close to 2 grand!
m16d, Oct 14, 6:22pm
Yer. wouldnt worry about it. Courier hasnt got enough power to push 5th gear anyway.
fordcrzy, Oct 14, 7:08pm
Common fault. Fix it, sell it, buy a ranger,problem solved
mugenb20b, Oct 14, 8:38pm
Awesome. Buy it and fit it, what's the problem!
horsygirl, Oct 15, 10:31am
Don't tow in 5th gear.
motorboy2011, Oct 15, 11:55am
change the gear knob to a 4 speed one, problem solved :)
budgel, Oct 15, 4:56pm
4WD!
kecal, Oct 16, 2:32pm
2wd
kecal, Oct 16, 2:33pm
i havnt towed with it
dent, Oct 16, 4:19pm
yes there is a kit avalible from a place called gear tech. By the time a mechanic pulls out the gearbox and strips it down and replaces the parts, reassembles and refits it to the vehicle. You will spend that $2000 and some. Unless you are doing it yourself!
1ollie, Oct 16, 6:04pm
Except the giant hole in your wallet or bank account lol
3tomany, Oct 16, 6:19pm
have you had it since new
kecal, Oct 16, 6:25pm
have you had it since newno
3tomany, Oct 16, 6:28pm
then how do you know it hasnt towed in 5th gear! Just pullin youre leg, it is a common problem with them towing just makes it worse
robbo36, Oct 16, 8:08pm
x1
Have you got a quote from these guys in Auckland! They rebuilt my L200 sport for 6 hundy. Just chucked it in the boot of the car, dropped it off on a Thurs morning and got it back on Fri lunchtime. Great service.
http://gearboxes.co.nz/index.html
kecal, Oct 17, 4:22pm
Robbo36doing nowthanks
panelvanner, Oct 18, 9:13pm
Broken 5th gear spacer. Ball drops out, circulates a few rimes without hitting anything, then, bang, ball gets picked up and through the gears. Fix it now. Cheaper to do now, than spend 2k on a rebuild.
