5 stud Wheel adaptors
cinad, Oct 13, 4:32pm
My son bought some mags.front sweet.back tyres are too close to the car body.
I've seen an aution for 6 stud 60ml adaptors.and I think we'll need 5 stud 40-50ml adaptors to make it work. only seen auctions with 15-27ml adaptors.
Where else can i get some wheel adaptors!
a.woodrow, Oct 13, 4:35pm
Hmm are spacers even legal!
NZTools, Oct 13, 4:37pm
Not legal
patiki1, Oct 13, 4:37pm
Try Znoelli
morrisman1, Oct 13, 4:50pm
legal up to 25mm
brokebloke1, Oct 13, 4:54pm
if the wheels are too close to car body wouldnt spaces make them even closer! sounds like offset wrong what type of car is it!
franc123, Oct 13, 5:27pm
sheesh if you need spacers that thick you've got the wrong wheels for the car. Any spacers need LVV cert which generally isn't a problem if you're sensible about it, even if you are fitting wheels only you are only allowed 25mm difference in track width before cert is needed. You'd most likely be laughed at and told to get the correct wheels if you tried to fit those.
unbeatabull, Oct 13, 5:30pm
You sure about that!
cinad, Oct 13, 6:31pm
I'm probably describing it wrong.
its a toyota camry 91 offset! i heard them say something about 5.5!.their dad didn't look into it enuf before he bought them.
