2003 ford courier king cab turbo diesel manual king cab 2WD
just noticed the fuel gauge not working ,are these fused ! as all the fuses i can find under the dash are intact,
went down and topped up the tank so the diesel is full,
the gauge moves a little bit when you turn the ignition onso there is power going through it
any ideas on how to repair ! where to start looking ! thanks
Nov 6, 5:59pm
It will most likely be the sender unit in the fuel tank.
kevlight,
Nov 6, 6:05pm
thanks, mugenb20bis this a job for a average home mechanic ! or is it for the garage, out of ten how difficult ! thanks Kev
Nov 6, 6:15pm
go drive on a bumpy metal road and see if it comes right . if it does then its the sender in tank at fault and needs replacing as it sticks at times
Nov 6, 6:41pm
Not a difficult job (4 / 10), maybe a little awkward when handling the fuel tank (a hoist and a third arm that you've just grown would come in really handy), takes a couple of hours to do the job. If you are doing the job at home, make sure the top of the fuel tank is clean. Bonus if it's a flat deck ute.
luxy,
Nov 6, 6:44pm
disconnect the wire to the sender. turn on ignition, earth the wire that you removed. If your guage goes to full then you have a sender problem. If it does not move then you have a guage problem
ml6989,
Nov 6, 8:16pm
As poster #6 says. If you do have to remove the tank, be wise and do it when it is empty!
n1smo_gtir,
Nov 7, 6:59am
yup as above, those floaty arms that shows you how much fuel left can get stick if owners always run to empty.
desertcolt07,
Nov 7, 10:22am
"fuel gauge not moving" infinite petrol!
kevlight,
Nov 7, 12:43pm
thanksluxy (977good info there, will try that first, i had noticed a gradualnoise increase, indiesel fuel sloshing noise, coming from the tank especially when half full and wondered if a baffle in the fuel tank was loose . now i have an urgent excuse to have a nosey ,under the ute, bugger that it is a canopy wellside, and access is rude if it is a broken baffle jamming the fuel sender is there a fix for that!
,i dont want to go to all the trouble of dropping the tank to get the sender out and leave the job half done , the ute is a 2003 ford courier king cab turbo diesel manual king cab 2WDwith 170,000 klms on it, thanks for all the good info,regards Kev
Nov 7, 2:44pm
Before you do anything -have a look under the ute and see if theres a ding in the tank. That might answer your question fast.
