Cleaning the exterior of car windows.
escapees, Nov 14, 2:50pm
Anyone have any hints or products they know to help me get the scum off my windscreen (the sort that appears when u drive into the sun on the motorway!).New car, rained last night and whe i was on the way to work caught the sun and couldnt see a thing! Someone said Jiff or ajax and hot water and then a wipe with meths! any ideas! thanks
m16d, Nov 14, 2:55pm
Jiff and plenty of water. Dont grind it in but.
next-to-normal, Nov 14, 5:06pm
acetone is good for getting wiperblade rubber off
splinter67, Nov 14, 5:57pm
Dont use jiff on your windows its an abrasive if ya cant work out why you shouldnt use it sell your car and ride a pushbike it will be safer for all of us meths will do it or try bars bugs
nzdoug, Nov 14, 7:13pm
Commercial glass scrub from automotive or glass outlets yhemRain Off exterior.
Rain beads off above 60 km without wipers!
Use them anyways.
Commercial glass scrub from automotive or glass outlets then Rain Off Exterior treatment.
Use them anyways.
phalanax, Nov 14, 7:44pm
Jiff works.i used it and its better than meths or many other glass cleaners just dont get to carried away with it.wash or wipe offafter
jmma, Nov 14, 8:44pm
Knew someone was missing, hows splinter67 (o:
splinter67, Nov 15, 5:51am
I am great mate had a good holiday how are you
intrade, Nov 15, 5:54am
i use newspaper. from a old friend who was a printer . the solvent in the newspaper from the black ink clean the muck.
splinter67, Nov 15, 5:59am
What dont flash lube make a window cleaner lol
kazbanz, Nov 15, 6:55am
STOP--is this a NEW car
andrewph, Nov 15, 7:12am
This will sound dumb but use blue glass cleaner and wipe off using news paper. It works. Lift the wiper blades off the screen and apply thinners to a rag and wipe the screen. If all else fails get a car painter to hit it with the polish and buff.
kazbanz, Nov 15, 8:08am
Sorry to sound like a know it all but first off if it is a brand new car Id be being a bit carefull at using anything at all untill you speak to the dealership.
If its a car new to you (second hand) then theres a sequence to use.
Just to explain.-when cars arrive from Japan the screen is covered in wrighting,a lot of it is wax crayon,Then its cleaned at the dealership but we want the car to look shiney so wax and silicone and tyre dressing etc gets splashed around. This ends up on the wiper blades and the screen
First off you need to use a product to remove all traces of siliconefrom the screen.-- 2k thinners etc. The blades need the same treatment (sometimes its better just to replace them)
Once that is done I prefer to use a windowpolish by pacer-this is a very fine cutting compound.
Usually this will remove everything
bellky, Nov 15, 8:10am
Brasso.
reggienz, Nov 15, 8:18am
Don't what ever you do use Brasso. It's extremely abrasive.
bellky, Nov 15, 8:21am
Use Brasso. Don't listen to above^ as they got no idea.
jmma, Nov 15, 8:35am
Blind stag (o:
trader_84, Nov 15, 9:22am
This .
kazbanz, Nov 15, 9:28am
Guys if you dont get the silicone off first youll just smear it around
splinter67, Nov 15, 10:42am
and dud has no legs as well
gman35, Nov 15, 10:56am
Yes kazbanz , most car co. detailers give me the sh*ts. Usually far too much interior shine on dash , tyre walls oily as hell , smearing for miles all over windows. Less is more guys !
socram, Nov 15, 12:17pm
Kerosene - its what the glass/screen fitters used to use and is non abrasive. I am great fan of diluted Simple Green too.
brad166, Nov 15, 3:02pm
1500 grit sand paper on a d.a with water, but you probably don't have access to that
crab2, Nov 15, 3:16pm
good grief I would never use any of those mentioned, after I have washed the car using the carbrush which has inbuilt soap I just wipe over with the blue window cleaning wet microcloth inside and out
