my 95 imprezza feels like it has a little play in sterring, im also wrecking a 94 legacy, wondering if i am able to use the one out of the 94 legacy or are they different! cheers
panicky,
Nov 19, 7:47pm
you sure its not the rack mounting bushes!
panicky,
Nov 19, 7:48pm
or tie rod ends!
panicky,
Nov 19, 7:48pm
or rack ends!
dasfi,
Nov 19, 7:50pm
na not sure, was just going to swap the hole lot over as i hve the 94 legacy sitting there!
richard112,
Nov 19, 8:26pm
Recall back about 5 yrs having our Legacy refused a WOF as the rack housing was moving in its mountings. Everything tight to the max. Cut copper packers for the mountings. (about 2mm thick.) No probs since.
hijacka,
Nov 19, 9:12pm
Quite common for steering rack bushes to wear out. If thats the problem then go buy some new polyurethanebushing cost about $50. the legacy rack will fit as long as its pwstr vs pwrstr etc
