OIL MIXING QUESTION
pugmyre, Nov 24, 1:50pm
Sorry for asking this question in the Motoring Section, a friend of mine has purchased a 9.9 HP Johnson Outboard.What would be the correct mixture!Would it be 50 to 1 or 100 to 1.The engine is old.It is a 1991.Appreciate any help.
johnf_456, Nov 24, 1:56pm
Most likely 50:1
bellky, Nov 24, 1:57pm
Google says:
"Everything after '64 is 50:1, TCW-3 oil." And:
"I had a 9.9hp Johnson (white housing)about that vinage and used 50-1. Seems like the manual said 100-1 for slow trolling, but to increase for higher RPM. I used 50-1 all the time and did not have any problems."
the_chooky, Nov 24, 1:57pm
If in doubt,start with 50.
pugmyre, Nov 24, 2:18pm
Thank you people.We appreciate your help.Many thanks.
pugmyre, Nov 24, 2:20pm
Bey Bellky.Sounds like it's the same sort of engine.Will do what you say.
therafter1, Nov 24, 2:23pm
Here is your mix ratio??
bellky, Nov 24, 2:33pm
Ok cool. That second quote when they said 'about that vintage' was referring to 1990.
The Google search I used was '9.9 HP Johnson Outboard ratio' on Web and Pages from New Zealand.
snork28, Nov 24, 2:41pm
http://www.csgnetwork.com/oilfuelcalc.html another handy site for mixture
pugmyre, Nov 24, 3:00pm
Thank you again everyone.Your help means alot.
splinter67, Nov 25, 6:00am
Hang on dont you use your computer for trolling
trademerob, Nov 27, 3:04pm
two parts oil two one petrol and one Banana Muffin.
icemans1, Nov 27, 7:28pm
make sure you add the oil yourself - NEVER TRUST PEOPLE IN A GAS STATION TO DO IT
