it was running really rough out the tail pipe, so i turned the dizzy on direction as far as it could go and it started running a bit smoother but the only problem is now the vowels are pinging. so i turned it back a tad so the vowelsdon't ping, it's running heaps better (still missing and putting a wee bit) any think else i can play with! Air on the carb!. Have replaced dizzy cap and rotor and plugs. Do you think it might be worth doing the leads!. Any help would be great!. Thanks
jmma,
Dec 4, 6:13pm
Has it got points!
fordoverholden,
Dec 4, 6:15pm
no it hasn't its electronic.
theram1,
Dec 4, 6:16pm
You need to do the timing properly, timing light.
craig04,
Dec 4, 6:17pm
Try adjusting the consonants.
fordoverholden,
Dec 4, 6:18pm
educate me, what is that!
snoopy221,
Dec 4, 6:22pm
craig04,
Dec 4, 6:23pm
bcdfghjklmnpqrstvwxyz of course.
fordoverholden,
Dec 4, 6:24pm
Ah i remember you! you helped out with the timing belt on my Suzuki swift. Na i turned it back i little so the vowels don't ping. Just be good to get it running smoother.
fordoverholden,
Dec 4, 6:26pm
Ah ha funi. Sometimes you gotta help a white brother out. English please:)
a.woodrow,
Dec 4, 6:27pm
Are you posting from a cell phone by any chance!
fordoverholden,
Dec 4, 6:30pm
no why is that
a.woodrow,
Dec 4, 6:30pm
cos your saying vowels not valves
snoopy221,
Dec 4, 6:31pm
wn oi wnt ta skool da VOWELS WERE. A
E
I
O
U
fordoverholden,
Dec 4, 6:32pm
aaaaaaahhhhhhhhh crap over tired and not thinking.
fordoverholden,
Dec 4, 6:33pm
HAHAHA i guess i asked for that.
andrewph,
Dec 4, 6:33pm
The language police say its valves not v\owels
fordoverholden,
Dec 4, 6:34pm
PC police
splinter67,
Dec 4, 6:37pm
leads would be a good idea hows the air filter and thanks for the laugh
snoopy221,
Dec 4, 6:37pm
Meh ya over advanced ya ignition timing by turning the spark making item.(distributor) causing pre-ignition or *PINKING* Timing light and get it timed RIGHT [No valves or vowels were pinged for speeding by da police ]
andrewph,
Dec 4, 6:49pm
Anyway im guessing its a "Y'' series, motor they can develop an air leak into the gallery for the idle circuit in the base plate of the carb. This can be tested by CAREFULLY spraying the base of the with brakeclean or similar with the motor idling. What actually leaks is the gasket between the body and lower plate of the carb not the gasket under the carb. It sucks into the throtle bore. This usually shows up as a rough idle or no idle.It will rev up a little if you spay at the throtle shaft ends. try that.
thunderbolt,
Dec 4, 7:21pm
Also done a few with leaking intake manifold gaskets, so spray around there also.
