I have checked and cleaned the front abs sensors and now im onto the rear ones and they seen harder to get out, is there a trick to getting them out or are they attached to something in the hub!
bevharris1938,
Dec 16, 7:46pm
ABS sensors are pretty hard to get out without braking them. You should be able to test them with a multimeter to make sure they are working without removing them. Next step is the ABS computer or get a auto sparky to test for fault codes.
unbeatabull,
Dec 16, 8:22pm
You need to check the tone wheel isn't damaged first before going to the ECU.
The rear's aren't a problem. The fronts occasionally get dirty with debris etc (usually after someone has machined the rotors and not cleaned afterwards!)
Very rarely does a fault come up due to dirty sensors - what is the reasoning for wanting to clean them!
