Any known faults with these or is it likely to be a genuine problem! Brakes work ok and voltmeter showing approx 13 volt when running
andrac63,
Jun 9, 8:01am
ABS
andrac63,
Jun 9, 6:11pm
have blown air around ABS sensors,not sure if cured as ABS light is intermittently on but battery symbol light stays on continuously,any thoughts!
beast9,
Jun 9, 8:07pm
get your alternator tested sounds like its giving up the go
pup2,
Jun 9, 8:22pm
"voltmeter showing approx 13v" It's poss the low voltage (due to fault with alternator), may be causing your ABS to log a low voltage fault. As above, head into a sparky or Ford garage and get them to have a look. Would expect a min 13.8v when running.
antwerp87,
Jun 9, 8:29pm
agreed your alternation will be causing abs fault. Auto electrician will be able to tell u what exactly as wrong with your alt.
nave12,
Jun 10, 5:39am
Yes,check the alternator for power steering fluid that may have leaked onto it also.But definatly sounds like the alternator is on its way to the tip.
jason18,
Jun 10, 5:44am
Mine runs at like 14.8-15v when running.
fordfan62,
Jun 10, 10:25am
Same for the xr.
nave12,
May 27, 8:52am
my 93 eb also runs up at about that.
