What sort of engine crossmember do i need and also what other nissan hubs will fit i know a31 s13 and c33 hubs will bolt straight up what other hubs will bolt straight up!
fordkiwi27,
Dec 19, 5:14am
moving to aussie but keen on swaps.
falcon15,
Dec 19, 5:32am
The crossmember in the laurel will bolt up to the neo engine. rear hubs you can use any rwd 5 stud hubs except gtr and 300zx as they take different axle splines. Front hubs you will need s14, s15 or rwd stagea 5 stud hubs and lower control arms or aftermarket 5 stud hubs that bolt to the standard s13, a31, c33 hub spindles which are different. Skyline front hubs wont fit they are a totally different setup.
