Any tips appreciated. Have put a commercial mixture through it which has helped but hasn't removed all of the corrosion. These can't be rodded because of their design. Phosphoric acid has been suggested. The only supplier that I can find can only supply 20 litres. Some one else suggested using a cow shed hose. Anyone who has had any success with this please let me know what you used. Thanks . (A replacement core will be about $3,000.00).
tmenz,
Jan 7, 9:49am
Send in the bees!
andrewph,
Jan 7, 3:11pm
Take it to a radiator shop. They are usually quite good at making the impossible happen.:o)
javlin,
Jan 7, 6:51pm
Tried that. Miracles must have been off the menu that day.
panicky,
Jan 7, 6:54pm
could go see the local engine reconditioner or local electroplater and see if you can get it dipped in one of their tanks
mrfxit,
Jan 7, 7:11pm
ANY chemical that will eat corrosion, will probablyeat the rest if left too long.
Try to find a mild corrosion eating chemical & do a few more soaking flush's.
Personally I would probably seal it up with a cleaner & strap it to the top of a vibrating bath (metal parts vibrating polisher) for a few minutes.
splinter67,
Jan 7, 7:41pm
Try the one in Napier Campbell radiators the guy there is awesome
