We have a 2002 MPV which I believe has an issue with it's Fan Control Module, as this was a known fault on these models in which Mazda did some sort of recall. The fan on ours runs when the motor is cold before its even started (A/C is off) and yet when the motor is hot the fans will not start at all even when you turn the A/C on. Has anyone had experience with this! is it easy to get a replacement module!
cpnnz,
Feb 10, 7:23pm
Could be the fan control module, or temp sensor. Might pay to get it diagnosed properly. I think the recall was in the US, I could not find any info on it for Japan or NZ when I looked into it recently for a 2002 model which had much the same issue as yours with fans on from cold sometimes. Mine did work as normal when hot though. It was a faulty control module.
blue_meanie,
Feb 11, 7:36am
Thanks for the reply, will definitely get it checked out to confirm, any idea on how much one of those costs if it is that!
cpnnz,
Feb 11, 8:20am
$150 used to about $300 new I think. I fitted a used one.
mm12345,
Feb 11, 8:56am
That would be about right.OEM part is US$75 on Ebay, and <$30 for a new aftermarket part. If you double the US price, then double it again, you get a good approximation of NZ retail price. I just bought an OEM part for my dishwasher.$NZ125.00 here, price in the UK was £5.95, all up including shipping about NZ$20. It's not just car parts - jeesh we get fleeced here.
