Turbo question. We have a subaru imprezza if has just started making a blow off valve sound and boosting real hard it does not h
happygabi,
Mar 19, 6:57am
We have a subaru imprezza. If has just started making a blow off valve sound and boosting real hard. It does not have a blow off valve. Is this going to cost us! Is it the boost controller!
familiadude,
Mar 19, 6:58am
have you put a boost gauge on it to see what its boosting!
happygabi,
Mar 19, 7:02am
No. Where do I get one and where do I put it! Should I go see a mechanic!
Mar 19, 7:07am
yea go see a mechanic to get the turbo wastegate operation checked myght be seezed or something. You need somone who knows about turbo and how to check things
Mar 19, 7:21am
http://www.youtube.com/watch!v=29gxsPrU9nE 1minute 52 the wastegate opens these can seez shut or open. seezing shut will result in turbo blowout seezed open makes swoshing noises and power loss. there is otherturbos also dont know what charger your car has my vw has variable turbo blade adjustment no wastegate for extreem boost at lowrpm already called a vtg= variable -turbo-geometrc. chargerthese can hang also especially if you drive them like a nana all the time the little blaed taht change the pitch seeze up. http://www.youtube.com/watch!v=kENxjxhoP24
vivac,
Mar 19, 5:13pm
Most likely a hose has fallen off the wastegate actuator or has perished and has a leak. Dont drive it hard, you could end up melting pistons.
