Is there a way to tell if a radiator cap needs to be replaced!
Mar 28, 7:58am
yea when you buy a new one for 8 to 18$ and you dont lose no water after. thats how you know the old one was bad. make sure its the right pressure one for the vehicle 80% of problems on cooling systems are from faulty caps.
fiatracer,
Mar 28, 9:34am
I'd suggest - if you suspect it might be, then just replace it and rule it out.
wifiabc,
Mar 28, 12:40pm
OK. I'll replace it and see if the problem of coolant gushing out of the expansion reservoir goes away.
xs1100,
Mar 28, 5:21pm
or if youdont want to spend the money take it to a mechanic and they ll pressure test it for you and charge you accordingly
