V8 people
black.ap5, Mar 24, 2:28pm
I have a 302 cleveland and would like to know if any body knows the firing order as i havent marked my leads
cheers
icemans1, Mar 24, 2:34pm
dr.doolittle, Mar 24, 3:02pm
As It's a Ford, probably 1,2,3,4,5,6,7 & 8 will give it a miss and fowl anyway.
petermcg, Mar 25, 10:55am
and it could depend what cam is in it also, there may be two options
nightboss, Mar 25, 11:33am
Can you explain how you did that link please icemans1!
outbidyou2, Mar 25, 12:37pm
http://lmgtfy.com/!q=
Save this to your favourites^ Use when you feel like being a smarta**e
nightboss, Mar 25, 12:45pm
Thanks OBY2, I promise to only use for truely deserving applicants for smarta**e awards.
quickstitch, Mar 29, 10:50am
13726548
therafter1, Mar 29, 10:55am
Your number one will be the first one on the R/H side. Engines vary with manufacturers of course, but on a vee one head will always be a little further forward that the other, normally the most forward cylinder is number one.
ljack, Mar 29, 8:41pm
No1 is first L/H side on a cleveland
bamz1, Apr 1, 4:00pm
302 and 351 clevelands have same firing order. 13726548 is the firing order.1234 down left side, 5678 on right if you facing engine from front.351 Windsor V8 has the same firing order, unless fitted with 289 or 302 cam.
