Anyone got any tips on how to do this easily. Have about 40 to do. Just found them dumped in my dads section. Then I can get rid of them at the dump much more cheaply.
Thanks
monaro17,
Aug 7, 6:31pm
Jigsaw perhaps?
Aug 7, 6:41pm
Big arse fishing knife does it, its going to be tough work doing that many. A power tool would be a plus.
bigfatmat1,
Aug 7, 6:44pm
cutting disc angle grinder gets through the steel easier
kenw1,
Aug 7, 7:06pm
Thanks people, have a big knife and will try it with a bucket of soapy water, then the jigsaw, if not then a sabre saw.
Just got to separate them into 3 bits tread, and 2 sidewalls, otherwise 25 bux each.
muzz67,
Aug 7, 7:15pm
Hoon around the sidewall with a big knife, just missing the steel belts at the edge of the tread. cut across the tread with a skill saw with an old blade. should be able to fit all 40 on a normal trailer.
ambo11,
Aug 7, 8:54pm
Put them on the side of the road with a $100 sign, they will all be nicked by morning
tard_me1,
Aug 7, 10:57pm
Nice one
skiff1,
Aug 7, 11:31pm
I use a sabre saw to do tractor tyres. Easy as
marte,
Aug 8, 12:14am
Angle grinders 'grab' when cutting into tyres. Its a pretty damn dangerous way to do it. Actually the most dangerous anglegrinder situation I have been it. I was cutting thru the rim of the tyre/ali rim to get the tyre off the rim so I could recover the rims for the ali.
bigfatmat1,
Aug 8, 5:08am
use the able grinder the correct direction next time :-)
muzz67,
Aug 8, 5:39am
grinders/jigsaw/recipro-saw,, all hopeless on car tyres. Tried them all.
Thanks all, big knife and sabre saw for the trucky type tyres. That will be fun the next time I am there.
Then we can fill the cage trailer up with bamboo and throw these on top, such fun :-)
m16d,
Aug 8, 6:49am
Grinders are good for filling the workshop with smoke.
Aug 8, 6:54am
SHARP stanley type bladed knife. cut into sidewall where it joins the tread. Cut in a circle and bingo sidewall on one side detached. repeat for the other side. You should end up with two flat disks and a flat "belt" of tread. This is the way I understand its done properly
seadubya,
Aug 8, 7:32am
I have seen them cut successfully on an old bandsaw.
brapbrap8,
Aug 8, 9:42am
Offer them to your nearest farmer, most would happily take them off your hands for silage stacks. I got about a dozen truckloads of tyres delivered for my silage stack and that was barely enough. Tyre shops actually have a waiting list of people wanting old tyres.
i used a standley knive and the other day my swiss army knive i then fold the tyre flat and tye it with string while standing on it and then it fits in the rubbish bag the whole tyre ;)
Aug 8, 5:21pm
there is no waiting list in whangarei i can guarantee you that the tyre guy gets charged extra for disposal of his cut up tyres in his huge rubbish bin. and they charge almost 5$ a tyre as whole its why i put em out with the bag in the rubbish.
richynuts,
Aug 8, 5:53pm
Silage not so common now as most farmers are making baleage nowdays.
marte,
Aug 8, 6:34pm
I used to work a milling machine in a machinist shop. As a floor matt to stand on, we had three strips of truck tred tied together as a matt. It was exellent, kept you off the floor and didn't burn when hot metal chips hit it.
