Windscreen Ring scratches
shane038, Mar 21, 7:28am
Does anyone know of a way to repair Ring scratches on my windscreens of my cars? I have two cars and both have scratches in the drivers view from my Mrs wiping the window?
dublo, Mar 21, 7:51am
It would probably take a lot of polishing to cut down to unscratched glass. I have even seen this on a vintage Bentley where every pane of glass was scratched.
Option 1: New windscreens
Option 2; (After fitting new windscreens) repossess her diamond rings.
Option 3: If all else fails and you love your cars consult divorce lawyer.
bill-robinson, Mar 21, 8:59am
show her how to operate the demister properly then fit new screens
bigfatmat1, Mar 21, 10:44am
Replace her diamond rings with burger rings then park cars and play some cricket. Make sure you have glass cover first
lookoutas, Mar 21, 3:28pm
Suggesting?
racetoy, Mar 21, 3:31pm
use jewelers rouge to cut the scratches out
reb53, Mar 21, 4:16pm
If a windscreen place, or glazier, will sell you some cerium oxide you could get to work with a power buff, and a lot of care.
I've removed scratches from glass with it but it's pretty tedious, so you wouldn't want scratches that are too deep or you'll be at it forever.
clark20, Mar 21, 4:34pm
easy
make sure you have glass insurance. find a rock. and the rest is history
johotech, Mar 21, 4:49pm
Yeah, this.
If the windscreen already has a chip or two on the outside, a sharp bang with the side of a fist from the inside will make it replaceable, rather than repairable.
lookoutas, Mar 22, 7:47am
Terrible suggestions - I won't be able to sleep - (for the rest of the day)
trade4us2, Mar 22, 8:00am
I put a circle of thick leather in a power drill and put cerium oxide paste on it.
Don't let the windscreen get too hot. Wear a dust mask as cerium is not good to breathe.
https://trademe.tmcdn.co.nz/photoserver/full/371406954.jpg
franc123, Mar 22, 8:34am
+1, and the a/c in conjunction with the demister, about 95% of motorists think that a/c is used in summer only to keep you cool. Waste of time trying to polish it out, an amateur would probably end up putting ditches in it deep enough to distort the image you get through it, which if bad enough in the CVA would get chucked out at the next WOF ----> new screen needed anyway. That selenium oxide or whatever that abrasive crap is called is also rudely expensive to buy for what is it, it'd be money down the toilet.
pauldw, Mar 22, 8:54am
Meanwhile you're crouched on the driver's seat trying to get a drill between the dash, steering wheel and the inside of the screen. Good luck!
kazbanz, Mar 22, 9:03am
shane- I feel your options are
1) replace the screen
2) get the inside of the screen as clean as you possibly can and put up with the scratches.
3) take the car to somewhere like Novus and have them try to polish the scratches out.
mortluby, Mar 22, 12:47pm
I had a work wagon with an awful lot of stone chips from all the re-roading work being done around Chch.
Mentioned it to the guy doing the WoF check and how hard it was driving into work in the morning with the low sun at this time of year.
He failed it on the warrant and insurance covered it under glass cover.
Edit: spelling
trade4us2, Mar 22, 1:49pm
No problem. I have polished the scratches out of two windscreens and all the windows in this:
http://cdn.c.photoshelter.com/img-get2/I0000E0wee9VX0V4/fit=1000x750/MB63425.jpg
dublo, Mar 22, 6:26pm
Maybe I am a little dim, but what does that beautiful restored Wanganui tram have to do with this subject?
trade4us2, Mar 22, 6:41pm
The windows were scratched around the edges, from people who are not careful with sandpaper. But also, the glass was stored for years with newspaper between the panes. So the printing became etched on to all the windows. A day's polishing with Cerium oxide fixed them.
peja, Mar 22, 9:13pm
How much is it to have Novus do a screen polish? Inside is OK I think, just a lot of small scratches that have built up over years on outside
socram, Mar 23, 7:29am
This. Or make her wear (driving) gloves. Before cars had aircon, driving gloves often used to have a chamois leather back.
catwoman1974, Apr 18, 8:17pm
Sell her diamond ring to pay for a new windscreen
