XR8 BF MARK 2 6 speed manual center bearing
tootsie9, Mar 6, 6:22pm
Could someone tell me how hard it is to replace the center bearing on above car. it's floppy.
TIA
karlp2, Mar 6, 7:09pm
You should consider subscribing to www.fordxr6turbo.com They have an amazing amount of tutorials covering all falcon models and on the forums there are loads of helpful/knowledgeable people who will be only to happy to share good quality advice. These guys know falcons inside out. Signing up is free and is necessary to view the full site.
12shirl, Mar 7, 11:55am
Done mine. bought center bearing off trade me. Aussie store. for around $80 frm memory, just have to remove drive shaft. split center universal by center bearing and undo large nut. you will need a press to push center bearing off. pays to replace universal as well ( about $30 from BNT ) and pays to get drive shart balanced after. Ford were no help and said i had to buy whole drive shaft cost thousands. good luck. ps just read yours is manual. mine auto but should be the same.
tootsie9, May 8, 8:13am
Thanks for that will look into it. Unsure if it is the 30 or 35mm center bearing
