Automatic shaking while stopped in gear
zmnewzealand, Sep 11, 12:32pm
i have a Mazda Familia 1.5 auto, when stopped at lights some times it will shake/shudder but once changed into Netural it will idle normal, it also shakes with low rpm like its about to stall when in reverse. what would be the cause of this? cheers
thunderbolt, Sep 11, 12:37pm
When was the car last serviced and tuned?
zmnewzealand, Sep 11, 12:45pm
its had new oil and filter(engine), spark plugs, timing adjusted, coolant etc but nothing on the transmission, the tranny oil seems clean reddish colour no smell. cheers
2sheddies, Sep 11, 12:47pm
It could quite possibly be unrelated to the transmission, and be a simple low speed misfire due to a plug or lead breaking down. As above, have it fully checked, tuned and serviced if it hasn't been done.
andyb2, Sep 11, 12:48pm
Adjust the idling a little faster
zmnewzealand, Sep 11, 12:53pm
sorry forgot to mention plugs and wires replaced, ignition timing checked/adjusted. cheers
zmnewzealand, Sep 11, 12:54pm
adjust it faster than the manufactures recommendations? only seems to happen in drive and reverse while stopped, idles in neutral with no problems. cheers
tony9, Sep 11, 1:07pm
Idle Speed Control inlet leaking, not connected properly?
zmnewzealand, Sep 11, 1:17pm
will have a look, cheers
intrade, Sep 11, 2:48pm
what year?
and has it got aircon?
tgray, Sep 11, 3:24pm
Engine mount would be my guess.
zmnewzealand, Sep 11, 3:36pm
It's a 1995 (engines a z5) and yes it has aircon. Cheers
zmnewzealand, Sep 11, 3:39pm
Thanks I'll check these also. Cheers
franc123, Sep 11, 5:04pm
I'd be removing and checking the large rubber tube between the airbox and throttle body for any splits in the convoluted areas before going any further with that one. Very common problem. A throttle body clean would also be good idea.
zmnewzealand, Sep 11, 5:14pm
That has just been replaced aswel as intake manifold gasket as had a leak causing engine rough running. Cheers
zmnewzealand, Sep 12, 1:26pm
having a look today, mounts dont look too bad, but i think i can hear a slight hiss so i will have a very good hunt over the weekend for another intake leak. cheers
lookoutas, Sep 12, 3:49pm
My daughters Toyota does that. It's OK until the AC kicks in, and the revs drop to 600. If it's notched into N it stops.
I considered tweaking the idle so it doesn't quite drop to 600, but forgot to do it. Until next time - when I'll probably forget again.
tony9, Sep 12, 4:39pm
Later petrol vehicles will have an Idle Speed Control valve that is driven by the ecu to maintain idle. If you try to tweak the idle you might get unexpected results.
If the ISC has a leak or is not plumbed in properly you can get inlet air bypassing the air flow meter, in which case it run lean and rough if the ISC tries to raise the revs.
lookoutas, Sep 12, 4:45pm
Due to my knowledge, that's sorta why I forgot to look.
zmnewzealand, Jun 24, 3:00am
ok after looking at it this weekend( not my car so at different location) its got a misfire at idle seems to go away with increase in rpm, new cap, rotor, plugs and wires, plugs seem clean but maybe slightly hot, seems to be across all cylinders not just one. cheers
