BF XR6 Falcon shudder when taking off, does not do it if you take off gently. Was told it was suspension bushes have replaced them, does not do it when you put your foot down once you are rolling, any ideas please
rob_man,
Oct 14, 8:07pm
Driveshaft?
bobin55,
Oct 14, 8:08pm
upper radius rod bushes on diff.
mr_lovebug,
Oct 14, 8:17pm
It's a ford.
Can be anything and everything.
Start with Suspension rubbers and parts.
rob_man,
Oct 15, 10:41am
I thought it was the doughnut thingie on the driveshaft that caused the shudder in those.
mggd,
Oct 15, 10:45am
Engine or gearbox mount?
Oct 15, 10:50am
What transmission are we talking here.?
ntalke,
Oct 15, 12:04pm
BF will have the ZF Transmission
Would be interested when serviced and what Fluid was used
Sounds like something in the drive line
lookoutas,
Oct 15, 4:56pm
Are you sure you haven't got the flaps down?
v8_mopar,
Oct 15, 4:58pm
Mid drive shaft mount would be a good place to start.
cone1,
Nov 5, 6:14pm
x1
Yep check the drive shaft center bearing first. The rubber has probably deteriorated from around the bearing. If its vibrating when driving at constant speed the CV joint on the rear of the drive shaft may be worn
4piggy,
Nov 6, 6:55pm
also check the trans cooler hasn't failed contaminating the trans oil with coolant (common on these), the trans oil will have to be tested as you cant normally see oil colour changed, if it is contaminated the trans will require a full rebuild
mastertechno,
Nov 6, 6:57pm
DriveShaft
Nov 18, 12:31pm
BF XR6 what? Whether its a sedan or ute will make a big difference as to what could be wrong IF its a suspension or driveline fault. It may even be a misfire causing an issue like that.
