I'm sure it is supposed to be around 800 to 1000? Whats the fix? Also still getting a flat spot on acceleration sometimes. Put fuel cleaner and injector cleaner through but its only improved it a bit. Put.ting the Ac on brings the revs down
andy61,
Feb 11, 2:41pm
Is the thermostat working correctly? If not, it could be running on cold start idle speed.Change thermostat if necessary.
delerium1,
Feb 11, 3:02pm
oxy sensor or idle control valve.
motorboy2011,
Feb 11, 3:56pm
Air leak between the afm and throttle body, if it uses an afm.
jason_247,
Feb 11, 5:18pm
i had similar on a 3sge celica. tried a few things, everything made it abit better until it was smooth. cleaned throttle body and idle control valve properly. changed plugs. replaced faulty thermostat. adjusted timing.
then it idled but i still had a flat spot between 2 and 3.5k rpm replaced leads, cap and rotor and its much better now.
express,
Jun 24, 12:19pm
Yep I've just come back from and errand and did notice the temperature isn't getting up to normal etc etc-era. Thanks people.
