Ashlate drive oil spots
toysky, Jul 4, 2:17pm
Help please
What is available to clean oil drops off a ash plate drive? Urgent please.
ceebee2, Jul 4, 3:03pm
Do you mean asphalt?
If so buy a can of engine degreaser from Repco / Supercheap / spray on / gently scrub / hose off.
sanders4, Jul 4, 6:17pm
Do not use a solvent based cleaner otherwise your asphalt will be removed as well as the stain!
tub4, Jul 5, 6:29am
Pacer make a product called Multi Plus, I've use it straight on oil marked hot mix with good results.
We t the area then poor a little on, give it a wee scrub and wash off.
As said by Sanders4 you need to be very careful when not to use solvents as they eat asphalt.
Pacer have a branch in Christchurch
reb53, Jul 5, 7:47am
Don't use a can of $3 degreaser from Supercheap. Tried some a few weeks ago and as stated above started to soften the asphalt.
xr6turbo2, Jul 5, 2:02pm
Just leave it and it will go away in time.
cagivachick1, Jul 5, 2:36pm
what he said
saki, Jul 6, 8:36am
Asphalt is oil based a few drops of engine oil will be like giving it a drink.
ozz1, Jul 6, 1:13pm
dishwashing liquid and hot water with a brush.
