Just started chewing out l/f tyre and pulling left under brakes, anyone had this problem or know what its about?
Oct 24, 7:54am
its had a wallop there and needs sorting out would be my guess
jimdaddy,
Oct 24, 7:57am
We've had it for ten years or so and hasnt taken any hits in that time and this problem has only just started.
jimdaddy,
Oct 24, 7:59am
Also the turning circle seems to have tightened and deels like its pushing across as if its in 4wd.
mainlander05,
Oct 24, 8:01am
You may have a brake binding causing it to pull left.take it to get checked real quick as its not safe under braking.
jimdaddy,
Oct 24, 8:06am
Trad, i do most of the driving but my father drives it occasionally.
martin11,
Oct 24, 8:06am
Something is worn in the LH Suspension ? Get it checked on a wheel alignment machine ? When was that last done ?
jimdaddy,
Oct 24, 8:06am
The tyre wear is on the outside edge. Camber seems to have changed.
jimdaddy,
Oct 24, 8:08am
Yeah dont think its had a wheel alignment in the time we've had it.
martin11,
Oct 24, 8:10am
10 years it should have been done when you put a set of new tyres on it . Sounds like a joint is worn
jimdaddy,
Jan 8, 8:35pm
Oky doke, looks like we'll be taking that to the mechs. Cheers.
