Has anyone done this and have a parts list, I know will need turbo, exhaust manifold but not sure about injectors and fuel pump. your advice appreciated.
mrfxit,
Oct 10, 6:19am
Yep it's all different. Turbo Injectors Injector pump Exhaust manifold Inlet manifold Probably air filter system as well
Is your TD27 mechanical or electronic injector pump. If electronic, you will probably have to change the engine management computer .
Also need to run a lower boost then factory for good life span because the engine wasn't set up for a turbo originally.
Remember that you will suddenly be running that engine a lot harder then it's ever been before. It would be a bit like borrowing grannys car thats only ever done 50kph for 15 minutes with just the driver . to a similar effect to taking it on a 500km trip towing a 2T trailer & 5 mates AND back again AND without doing any maintenance before going.
rob_man,
Oct 10, 7:40am
I thought a TD27 was already a turbo motor.
Oct 10, 8:09am
Add an LVV cert to the above list.
mals69,
Oct 10, 12:50pm
Yeah a guy called Mr Nissan done millions of them ! Every D21 TD27 Terrano is turboed amongst others.
mrfxit,
Oct 10, 3:02pm
Yep so how do you account for my 96 Nissan van with a factory non turbo TD27 motor & mechanical injector pump
kingfisher21,
Oct 10, 3:16pm
Just whack a turbo on it, those engines are near indestructible, I've had a couple and added turbo's, one ran 30 psi all day and never missed a beat.
sanders4,
Oct 10, 4:20pm
also mrfixit many navarras ran a non turbo td27.
ozz1,
Oct 10, 4:27pm
oh joy. its NZealand. n# 8 WIRE IS THE SAME AS n# 6 WIRE.:)
depends a lot on how much power you want out of it. simplest is bolt turbo and manifold on, sort the pipes and tweak the fuel up a bit. more advanced is changing the injection pump and increasing the power.
not sure if the TD27 had the "light" pistons that some of the TD series had. the other forums should fill you in.
mals69,
Oct 11, 8:45am
x1
Hey teeth puller - news flash - your van is not a terrano is it ?
mals69,
Oct 11, 8:49am
That is why I said all D21 TD27 terranos amongst others - did not say they never put out a non turbo td27 - little johnny did not fair to well on comprehension in his school reports !
a.woodrow,
Mar 1, 5:01am
x1
Wrong again. Early D21 terrano were available in turbo or non turbo. Stick with what you know.
