Vibrations trhough steering on L/H turns
millerz08, Feb 11, 2:02pm
On L/H turns at low speed/stopped there are vibrations coming through the steering wheel.
Any idea what could be the issue (Ford Flacon Bf 2006 xr6).
mechnificent, Feb 11, 2:12pm
If you raise the revs a little does the vibrating stop or change speed ?
Does the power steering pump belt squeal?
millerz08, Feb 11, 2:17pm
Will get my husband to check those things when he gets home.
Only purchased it the other day, so have only driven it for 2 days.
It had a AA inspection prior to purchase, that the seller arrange.
The report mentioned some vibration on L/H turns but when I spoke to them they said the car was in good condition, and should not require any unexpected repairs- other than a split diff mount.
millerz08, Feb 11, 2:19pm
No power steering squeal at all.
Just the vibrating sound and feeling on low/stopped speed when turning left.
Its booked in for a service and I have mentioned this issue also, but wondering what the cause could be. As I have to wait till next week to get it to the Mechanic.
homeless_guy, Feb 11, 9:05pm
Wheel bearing more than likely.
When turning left the offending wheel is on the outside of the turning radius and thus is taking a greater proportion of the load at the axle.
Get someone to jack the wheel, place a stethescope on the inner hub (or a screw driver handle pressed against the ear) and rotate the wheel slowly. Placing your finger tips gently on the inner hub while it is rotated can also help detect 'rumbles' and 'grumbles'.
millerz08, Feb 12, 5:16am
ok I will get my husband to try that this arvo.
tamarillo, Feb 12, 5:21am
Wheel bearing sounds good but you say it does it when stopped. Wheel beari g can't make wheel vibrate when cars not moving surely.
If cars is dead still and still does it surely it's something in steering assistance?
But of course cars are magical contraptions and only wizards in overhauls and a life's learning of that singular model can really know.
You'll need a wizard named Bruce for the falcon.
ntalke, Feb 12, 5:57am
My money is on either the upper or lower Ball joint on that side as these are a common problem
There is plenty of other areas to check as well as there is plenty of other Bushes that get tired as well
jmma, Feb 12, 7:59am
Lump in tyre?
poppy62, Feb 12, 12:25pm
Working on the premise that motion causes the vibration and that it occurs when Stopped (as well) I'm of the opinion that it is a broken/split Engine mount. 2nd guess would be steering box damper, although I have to admit I'm not sure of the Fords steering layout (Rack or steering box).
mechnificent, Feb 12, 1:25pm
This. If it's a high frequency sort of a shuddering/chattering. If it's slow and comes through or makes the steering wheel shudder it is more likely to be something in the steering.
If it is a ball joint it should be able to be felt with the fingers.
afer_daily, Feb 14, 3:27pm
not the Beach Boys (good vibrations ) ?
cone1, Feb 24, 7:52pm
I have a 04 BA XR6, All joints and wheel bearings are in good condition.
It has a shudder when turning lock to lock. Definitely in the steering rack and gives the feeling of air in the hydraulics? Fan belt is tight and fluid level is full.
tamarillo, Feb 25, 5:53am
What was it op?
bjmh, Feb 25, 6:07am
I had one here like that. unbeatabull. a guy on here . suggested retightening the 2 bolts that secure the rack,really swing on them . it fixed my one.
tamarillo, Feb 25, 7:30am
That sound plausible especially if it worked!
kazbanz, Feb 25, 9:05am
hang on--was that a FULL pre purchase inspection or one of those advertising sheets hung in the window?.(one page inspection)
If its the latter then I would be right away paying for a FULL pre purchase inspection because they aren't worth the paper they are written on.
gmphil, Feb 25, 9:58am
heard a story , that this happened to friend of mine the garage replaced the main pressure hose and solved problem ?
hollandia, Feb 25, 12:43pm
The wheels have been turned lock to lock when on the hoist, this is a no-no with these models, sometimes the shudder will fade with time otherwise replace hose (now modified) as above posting.
cone1, Feb 25, 3:42pm
Yes wheels were turned lock to lock and it did happen after that but if you go for a WOF check they do the same and there are no VTNZ bulletins regarding this issue on BA Falcons
cone1, Feb 25, 3:53pm
Interesting fact regarding steering shudder. I had just replaced the front disc pads in the BA XR6. I tried the same pads into another falcon and that car started the same steering shudder?
thunderbolt, Feb 25, 6:58pm
Steering shudder or brake shudder?
cone1, Mar 8, 7:17pm
Steering shudder, car standing still with engine running turning lock to lock.
millerz08, May 10, 1:03pm
Took it in for a service, and also got the power steering fluid changed.
No more shudder, so my guess is air in the power steering.
As some one mentioned above, I think air gets in the lines if it is turned with the engine off. (from my understanding anyway).
