Airbag light Flashing 97 Nissan Cefiro
puddleduck00, Aug 9, 2:54pm
My airbag light just started flashing randomly while the car is running. I've done the airbag light reset procedure, but the light just came back on. So I'm guessing there's something wrong with the SRS.
Should I take this to an auto electrician, or is this something that will require a Nissan dealer to look at?
Anything to do with airbags is usually pretty expensive right?
Thanks in advance.
franc123, Aug 9, 3:32pm
Yes either of those two places is best, as for cost to fix well it depends totally on what the problem is. Most SRS faults tend to be wiring and connector related instead of outright part failure related. Clocksprings are a common fail point.
puddleduck00, Aug 9, 3:39pm
That's reassuring. Hopefully not the whole airbag. Will get it diagnosed.
tamarillo, Oct 29, 4:26am
Hopefully they can simply scan and get the code which will be specific. Assume can do in this.
