Alternator charge light flashing
pdc1, Feb 28, 7:10pm
an old J15 Datsun engine - haven't had a look at what alternator it has on it yet, or checked charge with voltmeter yet, but the charge /alternator light flashes on and off at idle speed. As you increase the engine slowly above idle, the light flashes slower and then goes out as you increase the revs to approximately 1500rpm.
The machine has been parked up for about 15 years. What is the normal cause for this!
shall, Feb 28, 7:11pm
Stuck brushes !
shall, Feb 28, 7:12pm
Tap it with something and see if comes right
pdc1, Feb 28, 7:27pm
I'll try the tapping tomorrow. Just thinking through what to look for now, as you do in the evening.
The flashing is very regular, on and off pretty much equally. Once engine is running fast enough, the light doesn't flash at all. I would have thought if it was the brushes it would be more intermittent.
I don't even know yet whether it is an internal or external type regulator.
kenw1, Feb 28, 7:29pm
Belt tension!
bigfatmat1, Feb 28, 7:32pm
HIT IT
theram1, Feb 28, 7:41pm
"The Machine".
pdc1, Feb 28, 7:46pm
So how hard do I hit it! I would imagine that I would just try tapping around the back end / outer casing with a block of wood!
a.woodrow, Feb 28, 7:58pm
Yep thats a good way to go, don't hit it to soft but not to hard either - somewhere in the middle
shall, Feb 28, 9:28pm
just enough to jar it a bit but not smash the housing,
it could be other things, but bad brush contacts could be one of them,
intrade, Mar 1, 6:26am
worn down brushes its a old car i changed brushes on my 82 nissan ndatsun in 94 already and in 97 it went to the dump due to rust from the lime when they tarsealed the road here.
elect70, Mar 1, 2:05pm
The tap job will last long enough to reach auto sparkys place .
gsimpson, Mar 1, 2:23pm
When it breaks you know you have got to the hit it too hard point.
pdc1, Mar 1, 2:30pm
Thanks for everyones help. Tapping didn't work, so I pulled it apart and cleaned it up, and put it back together. It was pretty dirty around the brush holders. Seems fine now.
