I have a 1996 r33 gts25t skyline (automatic) and from time to time it feels like the trans skips gear and over revs, and wont click into gear so i have to pull over turn the car off and turn it on again and then the problem goes away. i have made sure there is enough automatic transmission fluid in the trans as well. would anyone be able to help me with what they think the problem could possibly be? cheers
martin11,
Dec 8, 11:17am
How long since the transmission was professionally serviced ?
midis,
Dec 8, 11:51am
about a year ago. will be getting it serviced shortly
martin11,
Dec 8, 1:01pm
I had a r33 gts25 and sold it at 200,000 km and it never had any problems with the auto but I had it serviced every 60000 km . Hope ts an easy fix for you . Aceomatic in Chch are very good . Perhaps they have a branch up your way .
Jul 17, 7:06pm
you need a transmissionspecialist if you want to have a look your self for function you would need nissan consult 1 clone tool , at a guess you have a silanoid play up or a wiring fault silanoids have internal wiring also whom can play up . I would talk to a automatic transmission rebuild place they would have the most clue and the tools to diagnose the problem i would guess.
