Rover V8 dizzy help
explorer10, Aug 23, 3:24pm
Looking down from the top, which way does a Rover V8 distributor turn? Auto electrician has put guts of pertronics ignitor from designed for Rover V8 into Triumph Stag Dizzy, increase in revs = retards back 0 degrees.
msigg, Aug 23, 3:31pm
crank it or stick it in gear if manual box and rock it, that will tell you which way it turns when running.normally retarding will idle slower.
tamarillo, Aug 23, 3:34pm
Movie cars 2 might help
bjmh, Sep 11, 5:33am
grab the rotor and see which way the centrifugal advance moves. dist will turn the same way.
