5 speed conversion cortina
psalter, Aug 5, 9:09pm
Hi all, I am swapping out my 4 speed (paying someone) for a 5 speed T9 sierra box but I need a new flywheel.
What am I looking for?
Also, when I get it done, assuming no surprises, what can I expect to pay? No-one seems willing to give me an answer on this.
TIA
unclejake, Aug 5, 10:16pm
Your flywheel choice will rather depend on which one of the seven Cortina engines you have, and then the ring gear selection will (I think) depend on how many teeth your starter motor has
psalter, Aug 6, 4:12am
2L pinto and pass.
woki, Aug 6, 7:29am
If its going into a MK 3 to MK 5 . You use Cortina or sierra flywheel and clutch . Use an auto Cortina gearbox mount and driveshaft .
psalter, Aug 6, 10:15am
So I shouldn't need to change the flywheel and clutch at all?
Is the sierra cross-member enough?
bill-robinson, Aug 6, 11:43am
why would you want a 5 speed?
elect70, Aug 6, 12:25pm
2l pinto to sierra 5 speed is bolt on conversion put new clutch plate in . Should be able to do it in an afternoon . . while your at it get a mild head job & headers give it a bit more oomp
psalter, Aug 7, 2:26pm
Because I am keen on driving intercity without ringing the he'll out of my engine.
bill-robinson, Aug 7, 5:08pm
okay, new one guy who did that,then ended up changing the diff ratio.
esky-tastic, Aug 7, 6:10pm
Sounds good, keep us posted on how it works out.
esky-tastic, Aug 7, 6:12pm
But then you'll lose your acceleration around town or if towing.
woki, Aug 8, 8:26am
will bolt straight in using an automatic gearbox crossmember , ( slight file to oval the hole to line up needed ) Use an automatic driveshaft will be correct length and fit straight in .
. will also need sierra speedo cable as is slightly longer .
Will make the car a heap nicer car to drive !
psalter, Aug 8, 8:44am
Thanks muchly. so to confirm, I do not need a new flywheel?
I won't be using that joker then.
elect70, Nov 4, 7:02pm
I did the 2L pinto & 5 sp into mk 1 escort mildly modified . Was a great little car drove it long distance reliable & quite economical . donk came out of a mk 3 cortina GT auto& 5 sp box flywheel & clutch from sierra , both had the tin worm real bad & were write offs . I p u t the GT instrument binnacle in as well with all the gauges
