Cost to replace air intake hose on 2002 BMW 316ti?
meat_loaf20,
Oct 15, 10:17pm
Earlier this year when getting my car serviced, Jeff Gray BMW in Palmerston North found a fault which is described on the invoice in the following way:
BMW Diagnostic Tester Fault found for additive mixture adaptation Cause: Air leake - intake hose has split Remedy: Air intake hose replacement
I didn't get this problem fixed immediately and now, according to a Google search, it is the cause of rough idling in the car which only started happening after I topped the car up with oil.
Does anyone know how much this might cost me to get replaced? Some people have suggested to me doing it myself, but I am definitely not the sort of person that can do much under the hood.
unclejake,
Oct 15, 10:53pm
If the rough idle started immediately after you topped up the car with oil then I'd be suspicious of a crankcase pressure leak (from the oil cap). but to answer your question: the actual labour involved with changing that intake hose is probably 15 mins. so allow a billable hour and then the cost of the part.
EDIT: and the last one I had to buy (for a Hilux) was something like $115
I'd suggest letting a mechanic diagnose your car rather than having any faith what-so ever in Google
saxman99,
Oct 16, 6:35am
As a temporary free fix you could find the leak and tape it up. This would also confirm that your rough idle is caused by a split intake pipe.
woodark,
Oct 16, 9:42am
Any Thoughts on the cost to replace C,V, Joints and also front diff on 95 Toyota Rav ?
Oct 16, 9:45am
question ? did they not show you where the intake hose had cracked and explain why it need replacing?
thunderbolt,
Oct 16, 9:47am
You would be better off starting a new thread on this, with clear info in the title. What is the issue with the diff?
unclejake,
Feb 6, 11:24am
Dealership workshops seldom operate like that mate. You usually deal only with a service manager who has clean hands
