Mineral scale/water marks on windscreen
quackbang, Mar 21, 10:46am
Gday team My windscreen has mineral type marks covering te whole windscreen and its bloody hard to see through, option one is find something to clean it or option 2 is break it for a new one. Any ideas what I could use to clean it. thanks
theram1, Mar 21, 11:19am
I have remove water marks from side windows and mirrors using paint cutting compound.
fatman08, Mar 21, 1:41pm
Yes, we had similar issues at the Onga Transport Depot in the '80s.
Tried the use of various chemicals, in the end would bring a couple of buses into the garage daily and had someone cutting the windows with cutting compound & airpolisher.
fordcrzy, Mar 21, 4:50pm
Yes use water based paint cutting compound. some will tell you all soets of rubbish like toothpaste jif and brasso which is all total rubbish. use only water based cutting compound that car painters use on thier machine buffers. simply rub on with cheese cloth watered down so its about like runny toothpaste.
ceebee2, Mar 22, 11:45am
I have used G2 from Repco on a power drill and it does an excellent job on auto glass.
franc123, Mar 22, 2:36pm
Use household steel wool.
trade4us2, Mar 22, 2:41pm
Rubbing by hand with Cerium Oxide on a damp cloth should work.
mrfxit, Mar 23, 7:31am
Almost right . ;-(
Steelo brand SOAPY Steel pads (NOT the stainless version)
Extra detergent & keep the froth down to a minimum with minimal water.
Flat hand with gentle strokes just the same as normal polishing methods
Rinse with lots of water when done
Done this on a lot of cars including our own when they get bad & normal washing won't work
mrfxit, Mar 23, 7:32am
Found out recently that it's also a common recommendation on USA camper/RV forums
beast9, Mar 23, 6:45pm
cut a lemon in half rub across window then wipe of with clean dry cloth works
petermcg, Apr 15, 12:15am
Yes this is the way, it works just like windowleen, rub it on, let it dry, rub it off. edit and I forgot to say this is how you do your glass shower door also,,, you can also use your random orbital with a soft pad to do the rubbing.
