Bloody son put brake fluid in the power steering.
wfl1, Jul 15, 8:36pm
reservoir , I have disconnected the lines and flushed through 2 litres of new PS fluid. Contaminated mix coming out is milky and is not clear yet Continue doing this until clear ? or is there something else I should be trying ? Any comments appreciated, Thanks
skull, Jul 15, 8:59pm
Was the steering operated with this mixture in it? If yes then the rack may need to also be flushed out.
rovercitroen, Jul 15, 10:59pm
Complete flush the only option. And still some seals may have been damaged.
jmma, Jul 15, 11:21pm
Are they both not hydraulic fluids?
How would this damage seals?
poppy62, Jul 15, 11:25pm
May be the difference in Silicone V Rubber. Brake fluid softens the rubber.
intrade, Jul 16, 12:39am
if you remove the return on the bowl you can purge and flush it . if its atf you probably need about 5 liters to flush it 2 or 3 stages . despose of the return fluid.
wfl1, Jul 16, 4:24am
Thanks for the comments , the residue PS fluid was just aerated oil and after a while when left for a while was almost clear which I will dispose of. Pumped though 2 litres of new PS fluid , and cleaned out reservoir of residue ,then reconnected reservoir and topped up and ran ,hoping should be ok.
martin11, Jul 16, 4:30am
Are you now going to teach your son how to service cars properly with the correct fluids ?
joanie04, Jul 16, 5:24am
I was going to say does your son have his licence? I am an older female and my father would not let be get my licence until I could change a tyre and knew all the different places different fluids were checked and topped up if need be. It did help that he was a mechanic with his own workshop and all three of us grew up in there helping.
I still religiously check everything every week.
briantamaki-god, Aug 1, 11:56pm
i taught my daughter the same joanie
however she wore short skirts and if she had a flat tyre she stood next to the tyre and she said within 5 mins someone stopped
tgray, Nov 7, 2:00pm
Go easy on your son. He was trying to help and probably feels terrible.
