My car has polycarbonate (not Glass )covers Bulbs are H4 60/55 to increase the light output I,m considering xenon? or H4 100/60 any ideas?
gpg58,
Jul 4, 12:36am
adding 66% more heat on high, sounds like complete new lights needed real soon. Whats the WOF rules on after market bulbs of any type, i would assume they would need to meet some form of approval. Spot lights wired thru dip switch seems better.
Jul 4, 12:38am
I'd be VERY carefull with 100/60's if you spend a lot of time on high.
gazzat22,
Jul 4, 2:01am
Guy I worked with at Air NZ had a Triumph 2.5pi and got so pissed off heading home late down George Bolt Drive Drive(when it was only 2 lanes) and one particular clown would sit behind him with lights on full.He put 130/90s in both headlights(Trumpy had 4)next time this turkey did his usual trick he slowed down,let him pass then gave him the "Treatment".Never happened again. Mind you the Triumph has glass headlights not Plastic.
tamarillo,
Jul 4, 2:10am
Are those plastic covers nice and clear? If not fix that first.
jmma,
Jul 4, 2:11am
Sealed beams?
wind.turbine,
Jul 4, 4:46am
Try changing the bulbs out to the 100% brighter ones, think hella or narva make them?
I have 120% brighter in mine and they are magic, only thing is with the increase of gas in them, they burn out faster then a normal bulb but you don't have the added heat like you would from a higher wattage bulb
snoopy221,
Jul 4, 4:50am
80/100's is about all ya going to need nowadays due to reflector signage. Back in the day 140/100's and 140's in the spots but nowadays ya just get too much glare
budgel,
Jul 4, 6:04am
Some of the new lights are insanely bright. I got blinded a few days ago in daytime by a guy on a bike with a very bright headlamp.
slarty45,
Jul 4, 6:14am
I swapped stock (bottom shelf) Philips bulbs for (top shelf) Philips Xtreme Vision Same wattage, no extra heat, just a much better filament but slightly shorter lifespan Good on open road when going like the clappers
lookoutas,
Jul 4, 6:16am
Yeah? Mate of mine had a mate who worked for Air NZ, and he procured him some landing lights that he stuck in the mains of his Trump 2.5. The bloody alternator almost jumped out through the bonnet when he flicked the lights on full. Main objective was to blind & piss-off everyone in Mangere.
gazzat22,
Jul 4, 6:19am
Nope .Not In Gerry,s PI or my 1978 2.5S
snoopy221,
Jul 4, 6:20am
procured him some landing lights Meh they are only 140 watts-lol
Read my post #8 LOL
And yep had the SERIOUS alternator with all circuits loaded rear window demister heater wipers lights stereo could pull over 100 amps-so had a cut n shut separate regulated battery sensed 4 cyl pulleyed alternator on a v8 which could put out over 150 amps at idle -LOL
gazzat22,
Jul 4, 6:28am
I heard about him.Apparently when he flicked the switch the alternator went right into red. He also hooked up a magnetron from a Microwave oven which took the signal from a traffic cops radar,multiplied it by a few thousand times and sent it back.He "Fried"about 10 radars until he got caught and told to "Cease and Desist or? He was an Avionics genius and a nice guy. From memory they were DC8 or DC10 landing lights TE 1978x. About 3-4 million candlepower.Those were the days!
supernova2,
Jul 4, 9:47am
Impossible as the PI Trumpy had sealed beams so not able to put high wattage bulbs in.
the-lada-dude,
Jul 4, 5:57pm
phisst, . that's nothing to grow about, I once had a 5.3 Triumph that I put 450 amp carbon arc lights in . on high beam you could set dry grass and trees a blaze as you drove on by . !
martin11,
Jul 4, 6:47pm
Rubbish your alternator /generator and battery would not stand the current draw .
gazzat22,
Jul 4, 8:14pm
Wrong!
gusthe1,
Jul 4, 8:38pm
I heard he once put a flux capacitor into a Morrie 1000 and hasnt been heard of since
Well obviously you didn't own any of the 10 or so that I had and every one of them had Lucas sealed beam units. Even the Rimmer Bros link shows them to be sealed beams GLU105 & GLU135
