I need the motoring gurus help please. im using a friends account so hopefully give you all reliant info. as i may not be able to come back and give more detail but will be able to read replies. I purchased a caldina FZ 2L turbo 2c-T motor chassy ct190 1997 sadly the transmission is nackered.clutch toqure convert and possible pump.
may trans code is A241L-01A ive been trying to source a replacement trans The wreckers have found me a trans the code is A241L-02B out of a diesel in my non turbo diesel other caldina the trans code is A241L-02A this chassy is a ct196 all three cars a 2wd and front wheel drive
can anyone explain what the last three letters numbers mean on the code Ive googled and even rung toyota dealers trying to find out if they will match
really appreciate any assistance you could give Thanks in advance
gpg58,
Aug 9, 5:33am
google result - not sure any help, but wonder if it could be worked out if it will fit by comparing parts/part numbers here? https://www.epc-data.com/
kevymtnz,
Oct 30, 6:06pm
throw the car away its worthless
