Nissan civilian 1989
oruff, Oct 30, 2:39am
5 speed box have trouble sometimes getting into gear when driving, ideas?
intrade, Oct 30, 2:42am
yea need a rebuild. sinchro rings gone .
kingfisher21, Oct 30, 2:43am
Could also be the clutch dragging or a faulty pilot bearing.
m16d, Oct 30, 2:44am
Got any oil in it. ?
mrfxit, Oct 30, 3:16am
Possible yes to all the above.
90's Nissan manual gearbox's not the strongest by a mile.
Even the auto's of that era suffer badly.
panicky, Oct 30, 4:50am
has it got a clutch booster?
ellroy, Oct 30, 8:14am
Is your clutch fluid level okay? Had one that had a stuffed slave cylinder that was leaking badly.
msigg, Oct 30, 8:51am
Yes to kingfisher, or could be pressure plate warped. If its box then a slightly lighter oil could help when cold.
franc123, Oct 30, 10:02am
One particular gear? All gears? Does releasing and reapplying the clutch make any difference? Worse when cold? More info needed. A linkage or clutch problem is more likely than something internal.
the-lada-dude, Oct 30, 11:27pm
any nashing of gears when trying to change gear ?
oruff, Dec 11, 2:47am
Leaking slave cylinder!
