Reverse transmission
fxx99, Oct 28, 7:56am
Can can handle reversing on the flat but any gradient the car really struggles. Is my transmission f'd and should I get rid of car ASAP or is it just something cars do ?
chrs
msigg, Oct 28, 8:04am
change the trans oil, if mitsi and high k could be stuffed. take it to a transmission center. Depends how much the car is worth.
snoopy221, Oct 28, 8:17am
Pedal cars DO do Just EXACTLY that.
Tis harder to pedal BACKWARDS.
AND.
With no make, year model and mileage GIVEN.
The crystal ball says
Pedal Car.
As it does.
m16d, Oct 28, 8:48am
Turn around and go forwards. ?
serf407, Oct 28, 10:54am
Depends on the car and reverse ratio the transmission the car has.Some transmission fixes cost very little if the solution is only a minor adjustment, if a common car with many quality replacement used trans from a dismantler/ parts importer then it should not be too much to swap in another trans.
intrade, Oct 28, 6:40pm
if you get rid of it asap then we will have a post from the next guy .
Somone ripped me off my car seems o have poor reverse what should i do and how do i get my money back.
gph1961, Oct 28, 6:49pm
tear a medium size branch from a tree and beat the vehicle
countrypete, Oct 28, 6:52pm
Simplest reason is low oil in the transmission. If it's not a sealed transmission, run the car till it's warm, then with the engine running, check the trans dipstick. Chances are it will be low, and adding auto trans fluid might fix your problem.
gph1961, Oct 28, 7:01pm
and if it does get a bigger branch
tmenz, Oct 28, 7:23pm
What if it's a Nissan Leaf?
lookoutas, Oct 28, 9:40pm
Transmission isn't even open yet, but you would be better off going forwards when it does.
mechnificent, Oct 28, 10:52pm
What do you mean by "struggles" ?
Does the engine rev up as much as it usually does with a bit of throttle, but the car not move?
Or does it over rev?
Or does the engine struggle to get up to revs and sound like it's down on power?
mrfxit, Dec 12, 2:50am
Perfect answer
