The first gen LaFesta's ive had were all as I describe.-the second generation ie the Mazda premacy with a Nissan badge was different. -but they didn't come out till 2012 (ish)
bigfatmat1,
Sep 21, 1:28am
jumped in one today remove battery from key remove plastic cap insert key use start button job done
Sep 21, 1:34am
what year was it mat?
cjsee,
Sep 19, 1:05am
Just after some help. Proximity key is working in my 2005 Lafesta. The fob also contains a removeable ignition key which i thought could start the car if the proximity key is flat. Just tried it, opens the door and fits in the ignition, but the key will not turn, so car won't start. confused? 'coz i am!
Sep 19, 1:40am
turn the key the other way up. Also take the weight off off the steering lock--ie grab the wheel and turn the steering a fraction to the left
slarty45,
Sep 19, 1:48am
how common is to have a stop/start button & ignition lock on same car?
used to have a mate called festa it was short for festering he had bad acne
cjsee,
Sep 19, 2:18am
Nah still nothing. steering lock isn't on and i cant turn the key paast the lock position. will shoot back to the dealer tomorrow, see if they can sort it. Thanks for the advice!
Sep 19, 2:29am
you need the key fob for the rfid information holding it close to the lock. The key is basically just to unlock the door and to unlock the ignition so a scantool can talk to the car for coding a key. i was on 2 day key training with aecs.net its quite a nightmare you also need a passcode for programming so i hope you have 2 fobs . 3 would be better we used launch pro scantool who is good on toyota and nissan .
Sep 19, 2:35am
Sorry intrade but that's a NOPE with the Lafesta and Most nissans of that generation. The Key does start the car normally CJsee--ok is your "key" ie the remote one shaped like a football or kike a credit card? Either way First thing is if the battery in the car is flat the key won't turn no matter what you try second-you do need to push the key and "knob' inwards a bit and have your foot pressing firmly on the brake pedal before the key will turn so check those three things first before anything else Just to be clear I have nissans of that age here and have both types of "key" -my instructions are based on having just "done" it
cjsee,
Sep 19, 2:39am
Would that still work if the battery was flat in the fob?
cjsee,
Sep 19, 2:40am
Like a football :-)
Sep 19, 2:52am
should do chips on old key have no battery there is a coil who makes a field to power the chip near the ignition point you got to hold the key there. should be in your owner manual?
Sep 19, 2:57am
Intrade-05 lafesta does start with that key. I suspect the car vbattery is flat or the OP isn't following one of the steps.
cjsee,
Sep 19, 3:01am
Owners manual is in Japanese. :-(
bumfacingdown,
Sep 19, 3:23am
I agree with kazbanz on this if the keys are anything like that hunk of shit Nissan I bought, (your description, not mine) it starts with the key out of the fob with out the fob being anywhere near the car
Sep 19, 3:28am
First thing is if the battery in the car is flat the key won't turn no matter what you try. so try tooting the horn or turning the car lights on-if they don't work you've found the issue. second-you do need to push the key and "knob' inwards a bit and have your foot pressing firmly on the brake pedal before the key will turn so check those things first before anything else
Sep 19, 3:28am
then the key would have the chip inside it or the immobilizer is turned off. The chip needs to be read look if you see the immo light flash on dash some wont crank some will crank start die when immo code is not passed on or is incorrect. for nissan i would have to read thru all the documents the ikey is the most difficult to bypass. older nissan nats is easy craked by hooking up a tacho tool to decript what the immo wants to see. as where the i-key changes each time you try hacking it.
bumfacingdown,
Sep 19, 3:41am
Which all makes this "you need the key fob for the rfid information holding it close to the lock. " wrong
Sep 19, 8:53pm
Crikey Intrade you really are overcomplicating matters. if you have the "football" shaped key fob in a Nissan of this generation the actual Blade type key DOES start the car on its own under normal circumstances. Ive got 6 Nissans right here with either the football or the credit card type "key" and tried it to remind myself
bigfatmat1,
Sep 20, 12:56am
I thought you put key in ignition then used the start button hence why it doesn't turn it's not meant to
Sep 20, 4:18am
nahh-nissans of that generation you still start them the old way ie turn the "key" except when the football/card "key" is doing its job you don't insert a key-if you know what I mean--so wjhen the fob battery is flat you insert key and turn -same way
bigfatmat1,
Sep 20, 5:04am
I thought lafesta was an different system I have struck this problem before I am sure it was a lafesta it's simply not meant to turn. I know the models you are thinking of and you are correct but I think this model is a exemption. Do you have one on yard. I think we do
Jan 14, 4:18am
it is complicated there is a few nissan systems aka "nats" nissan-anti-theft-system the key programming only covered nisssan and mercedes in 2 days . i would have to read thru the documentation the one was a wingroad with i-key
