My partners RAV4 lights keep switching off for no reason? I have pulled connections to bits and cleaned with no luck. It's not when you hit a bump or anything to do with heat as sometimes on start up they both won't go or sometimes only one goes? High been still ok wondering if this is a common issue with HID lights would love to fix myself as I know how much those auto sparkys love to chsrgr!
that sounds like the ballast needs to be replaced. BUT either you need the right test gear or you need to pay a sparky to test. just replacing a part based on info from the net is a silly solution.
frytime,
Dec 23, 7:44am
I would start by putting 1 bulb in it
