Wof - frame rust?
godimento, Aug 27, 7:22am
Hi, how bad is this frame rust, Is it a wof issue? No holes only surface. Also how should I fix? If I wire brush, treat and paint will they say i'm trying to hide something?
https://trademe.tmcdn.co.nz/photoserver/full/858159934.jpg https://trademe.tmcdn.co.nz/photoserver/full/858160616.jpg https://trademe.tmcdn.co.nz/photoserver/full/858162021.jpg
tegretol, Aug 27, 7:32am
What's the vehicle?
gunhand, Aug 27, 7:35am
That looks to be no more than surface rust. Clean it up and give it a paint or whatever. They can't fail on suspicion. It would possibly even pass as it is.
If they do say anything keep these photos and show them.
If ya keen give it a jab with a screwdriver, then you will know for sure.
gammelvind, Aug 27, 7:47am
Wire brush the loose rust, spray 2 coats of Dinitrol RC900 (aerosol) then overcoat with either a colour matched paint or underseal it. Dinitrol 447 in a can. All available in Tauranga.
rctr, Aug 27, 4:45pm
Fail at vtnz may pass with a comment every where else
kazbanz, Aug 27, 4:47pm
"Funny" isn't it--THAT would be an instant Compliance fail.
IMO -decent Bead blasting then seal then paint.
gph1961, Aug 27, 5:00pm
clean up
get wof
paint
msigg, Aug 27, 5:06pm
Yes easy wire brush and spray black or wipe old oil on it.
intrade, Aug 27, 6:49pm
clean it down check if no rust holes . use ripo-oil on all the rust
lookoutas, Aug 28, 1:41am
They've gone completely anal after that bus crash up the mountain. We're getting all sorts of shit that we haven't got time (or want) to do. For nothing. And within 28 days.
No quotes.
jkm, Aug 29, 7:55am
I would treat it with CRC rust converter then spray with fisholene, both available in a spray can from Supercheap and other suppliers.
clark20, Aug 29, 9:39am
happs1, Sep 3, 2:38am
Hi Im doing a similar thing Camper trailer. I brought some converter and got the spray first and thought I'm better with a paint brush. My question is after you use the converter do I need to rinse it off ,? Also what next please? . I don't have a clue. TIA
https://trademe.tmcdn.co.nz/photoserver/full/862244269.jpg https://trademe.tmcdn.co.nz/photoserver/full/862244426.jpg
jkm, Sep 3, 2:43am
If you use the rust converter it sets to become your primer/undercoat.
Then you paint straight over it once it is cured.
If you spray on the fish oil, give it a couple of coats and this will last longer than paint
happs1, Sep 3, 3:19am
Cheers for the reply
How is the smell as I will be sleeping above it
nzdoug, Oct 9, 7:57pm
Leave the vehicle out side for a day or two to dry out.
