Hey Truck drivers, Do large modern trucks have
gunhand, Oct 1, 8:01am
ABS or similar systems? I could google It but hey, no fun in that.
And yes something did happen to have me ask this
philltauranga, Oct 1, 8:08am
Yes since 2008 I think it was.
philltauranga, Oct 1, 8:09am
Ok gun. what happened?
serf407, Oct 1, 8:10am
Volvo trucks - there is other vids on abs systems
https://youtu.be/ridS396W2BY
horses7, Oct 1, 8:10am
ABS. EBS .Stability control,you name it,they pretty much have it all
gunhand, Oct 1, 8:15am
Well I wont go into great detail but did witness a large modern truck and trailer unit having to slow down bloody quick and take evasive action. Thing is I expected to see a bloody great lock up as I could see what was going to happen 200m off before it happened. So I just wondered, maybe they do. All those wheels and all I had to think.
bumfacingdown, Oct 1, 8:31am
"All those wheels and all I had to think."
And in the end, you did not have to think
gunhand, Oct 1, 8:35am
Well he could have had jolly good pedal control and remain calm in the face of and emergency. I did think, surly they must these days, but as I said, up to 46 tires to bring to a safe halt on some trucks.
serf407, Oct 1, 8:38am
Big tractor lock ups are fun to watch.
https://youtu.be/4PuN-JZnIZI
mack77, Oct 1, 8:57am
A 1994 Volvo FL10 that I used to drive had an ABS braking system, as I found out upon using hard braking to avoid a tractor that pulled out in front of me at an intersection. The tractor driver told me that he thought he was going to die, but the ABS brakes on the FL10 saved him. Until that event I didn't even know that it had ABS brakes.
Even although I was only doing 40kph it still took a surprising distance to bring the 44 tones to a halt.
philltauranga, Oct 1, 9:19am
Wow 1994, I didnt realise volvo had it that early,
NZ brought it into legislation in 2008. good move.
Some people dont seem to realise how far it takes a 44 ton truck to stop from 90kmhr, 200m emergency stop would be well done.
bigfatmat1, Oct 1, 1:34pm
Ebs was brought in in 2008 as mandatory on trailers. Lots had abs previously. Ebs lets the trailer(s) and truck all communicate via can bus also.incorporates anti roll anti slip stability control on truck and trailer also controls the steering axle on trailers. Anti roll has load sensors on trailer and controls the airbags accordingly.
rodeorunch, Oct 1, 6:17pm
Abs braking and disc brakes on the later models now
henderson_guy, Oct 1, 8:08pm
Trucks do. Many trailers on the road now still don't. It's very easy to lock up an unladen trailer under even light to moderate braking. Rather disconcerting when you touch your brakes and the trailer tries to overtake you.
lookoutas, Oct 1, 8:33pm
No - he didn't think he was seeing right, coz the statement should have been:
"All those wheels and all I had to drink."
Blame intrade's contamination.
tweake, Oct 1, 10:08pm
and when they are only 4m behind the car in front you know who is going to die.
tweake, Oct 1, 10:11pm
there was one locally where a car cutting the corner made the oncoming truck to jump on the brakes. the trailer, with incorrectly set brakes, swung round and splattered the car.
philltauranga, Oct 1, 11:08pm
Yes, tailgating is poor behavior, a problem I find on the Auckland motorways when traffic is flowing, is when I leave a suitable safe gap, it is instantly filled, so I slow to leave a gap again, its filled, slow-filled, slow-filled, I try my best but when traffic is heavy and still flowing, people just see the gap and fill it.
I doubt the trailers brakes were incorrectly set, the preformance of them is heavily monitored by the authorities using brake rollers at the weighbridges.
Its more likely it was an older trailer which cant distinguish between loaded and empty and adjust brake pressure to suit. They need to have the brakes wound up pretty tight to meet COF requirments, so when they are only lightly loaded or empty they lock up VERY easy.
rsr72, Oct 1, 11:22pm
Two weeks ago in Auckland. ABS weren't of much use to this fool.
https://trademe.tmcdn.co.nz/photoserver/full/634544883.jpg
philltauranga, Oct 1, 11:29pm
You should put up the news paper link, because you know very well that "fool" was swerving to avoid a car that cut him off.
But hey. just "blame the truckie"
rsr72, Oct 1, 11:31pm
Driving much too fast and too close it seems to me.
The short lock-up marks tell most of the story.
rover79, Oct 1, 11:34pm
ABS means, Anti lock braking system.
So that being the case, you shouldn't see any lock up.
rsr72, Oct 1, 11:34pm
Another fool on the Desert road last month.
https://trademe.tmcdn.co.nz/photoserver/full/652381204.jpg
Could easily have killed someone.
mechnificent, Oct 1, 11:41pm
New technology is amazing.
Not a truck trailer but. my son hired a tandem axle trailer the other day to tow behind his hilux to pick up another hilux. the trailer came with a unit on the trailer which was connected to the wiring, and another box that went in the cab. The two units communicated wifi and you could proportion the trailer braking. Bloody brilliant I thought. He reckoned it made a real difference between loaded and unloaded.
tweake, Oct 1, 11:41pm
i don't know what the truck had. i was told the driver forgot to set the brakes to unloaded setting but i don't know exact details.
still its a good example of why you don't cut corners.
