Trying to renew rego online and required to type in number plate which has a slashed zero in it. I'm on an iMac and when I do what is usual to produce a slashed zero, like this Ø, which is holding down Shift and Option keys and hitting 0, the NZTA robot tells me not to "create spaces." How does one do it? Of course I can go to NZPO to pay, but this is more convenient. Thanks
May 13, 9:03pm
its just a zero they only make that so they can tell on photos if its a O or a zero. if the zero dont work use the O
vtecintegra,
May 13, 9:03pm
Just put a normal zero (0) in
harm_less,
May 13, 9:08pm
The Ø symbol is an abbreviation for diameter so not what you require. As recommended above the slash through a zero is to differentiate it from being a capital O. Use the zero on your keyboard and all should be good.
zuggle,
Aug 9, 11:47pm
Thanks everyone. You sorted it!
