Cheapest place to get a Cambelt Replacement for VW
calebjames14, Sep 17, 12:11am
MK5 GTI
saxman99, Sep 17, 12:31am
Rather than an all-out focus on the cheapest option, I would be inclined to use an independent garage that specialises in the brand. Their price will be somewhere in between “cheapest” and “VW dealer” and you’ll have peace of mind that it’s been done correctly by someone who knows what they’re doing, using quality parts.
sport_billy, Sep 17, 12:34am
Check out local main dealer, often they do specials themselves and competitive (to independant garages) themselves - I've priced up and compared before myself:
https://www.milescontinental.co.nz/deals/
marte, Sep 17, 12:48am
Yep to both.
And find out what else could/should be done too. Coolant system stuff.
sw20, Sep 17, 12:49am
Just get one of those voucher type deals. They are usually cheap aren't they? What could go wrong?
msigg, Sep 17, 1:01am
Just ask around your area. You would want to do water pump and change coolant as well and might as well do oil change while there. Then good to go.
kazbanz, Sep 17, 1:43am
Where in Auckland are you located ?
tony9, Sep 17, 2:32am
The cheapest one you can find may well take the car for a day and put a new sticker on the cambelt cover. It really does happen.
s_nz, Sep 17, 2:59am
One of the voucher deals?
$469
https://new.grabone.co.nz/automotive/automotive-servicing/p/nz-cars-and-automotive-ltd-61
"Please note that some petrol and diesel engines may require idler bearings, tensioner bearings, other bearings, water pumps or other additional items that is best practice to replace when the cambelt is being replaced."
So if you want the waterpump done as well (you really should have it done), along with the seals, Tensioner etc. it will cost a lot more.
Also the belt won't be genuine VW.
I suggest calling or visiting a few mechanics and getting quotes for the scope of work you want.
rayonline_tm, Sep 17, 3:41am
Yup, it might be just the belt the other stuff like tensioners etc . water pumps are not included.
tamarillo, Sep 18, 4:17am
As above though genuine vw parts aren’t needed as there are lots of quality aftermarket parts. Have a look on rock auto if you’re looking to do it yourself.
If not just find a vw freindly workshop around you.
Best do tensioner and water pump at same time.
marte, Sep 18, 5:40am
I got 2x 253 tooth cambelt for my V6 Audi & 2x Drive belts ( alternator etc ) for NZ$150 from Rock auto this week. Inc P&P ( 2 boxes, from different storage places )
Continental brand
So, NZ$37 each Inc GST & P&P
Continental 40297 @ US$14.31 each
But if it's your own VW, get the good stuff, get the whole kit & seals etc & check the Crankcase ventilation system too.
CVS system is a 100,000 km replacement maintenance scenario ( along with gearbox & coolant system. )
marte, Nov 19, 1:51am
I'd go somewhere where they do do that job all of the time.
You want to be paying somebody who knows where every screw bolt plug & clip is, has the proper cam lock & crankshaft lock pins & jig.
Has the proper levers for removing & adjusting stuff & knows what order to do it in & what to look for.
There's no point in paying somebody to learn this 'on the job'.
