Yeah there's two. Same as the Blade. The 2nd one is not the easiest to reach.
Jan 20, 3:15am
Instruction to find second nut. -Buy $300 torch and $500 150mm straight edge push straight edge against the nut you undid and the power plug with about 75mm sticking up. Shine $300 torch at the top of the ruler. You will see the other nut.-actually you might not because theres a cable cover sitting on it. -Once you've undone it then I would use plastic levers to pop it off the other clips
Jan 20, 10:41pm
MOST of what I posted was correct.
saki,
Jan 20, 11:10pm
No it wasn't this is the correct way 300$.
Sep 26, 1:14am
Serious Instruction to find second nut. -Grab a straight edge and line it up against the exposed bolt and the side if that exposed wiring plug. 75 mm higher up you should see the second nut/bolt.-there is a wiring clip on the top of it you just pull off. Once you've undone the nut it then I would use plastic dash tool levers to pop it off the other clips
