Nissan qashqai
leogets, Aug 23, 8:31pm
Hi, I have 2010 qashqai with 220000 ks. The engine light has come on again after getting a service and 4 new spark plugs as advised by garage.Still drives great. Any advice please
franc123, Aug 23, 8:36pm
Were you told why it came on in the first place?
leogets, Aug 23, 9:00pm
They didn't know but tests showed nothing. They reccomended the spark plugs
franc123, Aug 23, 9:47pm
Check engine lights dont come on for no reason, it has to have triggered a fault code and a reason why they recommended what they did. If they recommended a plug change it suggests the code was related either to air/fuel ratio sensor function or catalyst efficiency, which is commonly related to worn plugs. They need to rescan it for you, if you dont get a satisfactory answer, go see a Nissan agent.
sw20, Aug 23, 9:49pm
I hope you didn't pay them real money for their non diagnosis.
leogets, Aug 23, 11:02pm
$60 for diagnostic scanner. Trouble codes P0420-TW Catalyst sys-B1 and $295 for 4 plugs
franc123, Aug 23, 11:16pm
OK well what has to happen now is a rescan and a look at what's known as freeze data to find out why the code was triggered, and if it is in fact the same code. It wasnt unreasonable to suggest a plug change for that code.
kazbanz, Aug 24, 2:19am
have you been doing a lot of short trips lately?
leogets, Aug 24, 7:32pm
yes not more than 10ks and once a week 130ks
kazbanz, Aug 24, 7:49pm
My gut feeling is that the sensor in your ?by your catalytic converter is gunged up. Replace that and all will be fine.
Please though.--that's just my opinion based on experience with zero diagnostic work done.
leogets, Aug 25, 6:20pm
thanks, got car booked in for thursday
sw20, Aug 26, 5:01am
Probably Iridium plated. Retail price + mark up from workshop. For and inline four cylinder with easy access to spark plugs I'd just use NGK/Denso copper plugs at $4-$6 each.
leogets, Dec 1, 11:42am
Hi, Nissan plugs are $41 each according to my bill
